Torsion bar tighten or loosen?
Old Oct 1, 2020 | 02:37 PM
Undatakr's Avatar
Undatakr
Default Torsion bar tighten or loosen?
The driver's side of my '04 Dakota seems to be sitting about 1/2 inch lower than the passenger side. I assume that a simple adjustment of the torsion bar is all that's needed(??) but should I tighten or loosen the adjustment bolt? Is there any "rule-of-thumb" regarding turns to height, i.e., does 1 turn equal 1 inch higher/lower?
Old Oct 1, 2020 | 04:01 PM
Tighten. That will raise that side.
Old Oct 1, 2020 | 10:47 PM
Vimes's Avatar
Vimes
No rule of thumb. Put the truck on a hard flat surface, bounce the suspension and measure from the ground to the middle of the fenderwell. Make your adjustments, and remeasure. If you want both sides the same, measure both sides at the same point, then adjust until they match. I'd take it half a turn between measurements to get a feel for it. After you adjust, bounce the suspension then measure again. Bouncing the suspension - put your weight on the bumper on each corner, and let off to make the suspension bounce. When it settles, measure.
Word of warning - if you're raising the corner (tightening the bolt,) jack the front end up on the side being adjusted. While the bolt threads can easily keep the truck up while static and loosening them isn't a problem, it's possible to strip or snap them when tightening with the weight on. Jacking up the corner being adjusted will take the weight, and the stress, off the bolt and it will turn much easier.
