Fan clutch nut size
Old Oct 20, 2020 | 10:05 PM
2000_Dakota's Avatar
2000_Dakota
Default Fan clutch nut size
Hey gang, what is the nut size of the fan clutch on my 2000 Dakota 4.7? TIA
Old Oct 20, 2020 | 10:20 PM
Dodgevity's Avatar
Dodgevity
36 mm
I used a strip of cardboard to protect the fan pulley and gripped the edge of the pulley (with the cardboard over it) with a channel lock. Locked the channel lock against something nearby and that stopped it from turning. With the pulley immobilized, I used a larger channel lock to pull the fan bolt. An open end wrench works too, of course.
Old Oct 20, 2020 | 10:34 PM
2000_Dakota
Thank you kind sir.
Old Oct 21, 2020 | 07:48 AM
I left the serpentine belt on, put an adjustable wrench on the fan nut, and smacked it with a hammer a couple times to get it to break loose. Once it did, I could spin it off by hand.
