Smoked PCM
Old May 2, 2021 | 03:31 PM
Robertwav1's Avatar
Robertwav1
Default Smoked PCM
Any input on this guys would help me out. I'm driving down the road and the truck quits, shuts down. I thought i seen a little smoke from under the hood near the PCM. Anyway a check engine light, P1388, P1389 which is the ASD no voltage? Check what I could but had to tow her home. The PCM is leaking some tar substance so it's cooked. Okay so I need another one but i'm guessing something took it out but don't know what to look for except for a grounded or shorted solonoid maybe that did this? It's a new problem and the only indication is that Auto shut down took place. Where to start I guess I'm asking. Starting my research now so any advise would be appreciated since I want to find out what caused before putting in another PCM. It's a 98 3.9L Dakota. Thanks!
Old May 2, 2021 | 03:38 PM
The PCM failure will immediately drop the ASD circuit, so, no power to coil(s) and injectors... Engine stops running RIGHT NOW.
The stuff running out of it is a sure indication that it is indeed cooked... As to what did it? Maybe just age.
Old May 3, 2021 | 11:00 AM
Robertwav1's Avatar
Robertwav1
Okay, so what if I jump the rely and fuse it of course, would that work?
Old May 3, 2021 | 11:51 AM
PCM only deals with the control side of the circuit. (which is already fused elsewhere)
Given the condition of your PCM, I would be very surprised if the engine ran at all...... You need a new PCM.
Old May 3, 2021 | 12:20 PM
Robertwav1's Avatar
Robertwav1
I do have one ordered, it takes a few days. One other question however is the fuel pump. Does the PCM cycle this thing or is it just powered up when truck is running?
Old May 3, 2021 | 02:02 PM
Fuel pump is controlled by the PCM as well. Couple seconds at initial key on, then, when it sees the engine turning.
Old May 5, 2021 | 10:33 AM
Robertwav1's Avatar
Robertwav1
Believe I figured out why the PCM burned. Found a hose clamp touching a small wire on the alternator and also the fuel rail. Finding out the regulator is built inside the PCM for the alt led me to do a visual. My fault as I had this engine apart a few times for head gaskets. Just one of those things that happen to me. I don't think I could arrange that clamp to do that if I wanted it to. Hopefully, it's the problem.
