New 4.7 in 2000 Dakota with no compression
Old May 16, 2021 | 01:22 PM
Murray Hill's Avatar
Murray Hill
Angry New 4.7 in 2000 Dakota with no compression
I have just installed a rebuilt 4.7 from a motor shop in California. It has had issues from the shipping, to a broken motor mount bolt in the block. I then discovered that the #3 and #4 spark plug holes in the head had bad threads.
Now that the engine is together I followed the start up procedure. I pumped up the oil, installed the plugs, purged the fuel rail, and nothing! The truck won't start. I checked the compression on #1 and #4 cylinders and I have no
compression. Does this mean that they have the timing 180 off? I'm not looking forward to taking this thing apart again so any ideas would be appreciated.
Old May 17, 2021 | 07:38 AM
Did you get the the whole motor, or just a shortblock from them?
Old May 17, 2021 | 03:39 PM
Murray Hill
No, it was a long block.
Old May 17, 2021 | 04:33 PM
Then it should come with a warranty. But, if you tore it down before talking to them about, your warranty just went out the window.
