Starting issue. Possibly ASD?
Old Jun 1, 2021 | 02:29 PM
Aftermarket alarm on the truck??
Old Jun 8, 2021 | 08:30 AM
Canadian Mechanic's Avatar
Canadian Mechanic
Nope, it's the stock alarm and security system. Just a question though, do you think an ignition coil would have anything to do with that? Losing voltage after it starts?
Old Jun 8, 2021 | 09:23 AM
Coil, and injectors get their power from the ASD relay. If you have power at one, but not the other, it's a wiring problem. If you don't have power at either of them, then its a relay, or relay control circuit problem.
Old Jun 13, 2021 | 05:37 PM
Canadian Mechanic
So it's not an ignition coil problem. And it's got no problem with fuel pressure, maintaining 48 I think, priming and idling. So I think it might be a security issue, something is shutting the truck off, it's getting fuel and air, what do you think?
Old Jun 13, 2021 | 09:09 PM
Gonna have to go looking for what's missing when it quits..... If it stays quitted for long enough.....
Old Jun 14, 2021 | 10:24 PM
Canadian Mechanic
So the next thing we are going to try is bypassing the oil pressure sensor, because I've read that those could cause similar problems. Thoughts?
Old Jun 15, 2021 | 08:40 AM
Oil pressure sensor? Nope. Has nothing to do with whether the engine wants to run, or not.
Old Jun 15, 2021 | 08:59 AM
Canadian Mechanic
Okay. What about an oxygen sensor or MAF sensor?
Old Jun 15, 2021 | 09:06 AM
If it doesn't fire at all, even on starting fluid, you need to look at why you aren't getting spark.
Old Jun 15, 2021 | 02:40 PM
Canadian Mechanic
I'm gonna try to bypass my O2 sensor, see if that does anything.
