Starting issue. Possibly ASD?
Old Jun 15, 2021 | 02:43 PM
  #21
O2 sensor does nothing at startup.
Old Jun 15, 2021 | 03:07 PM
  #22
Canadian Mechanic's Avatar
Canadian Mechanic
If it doesn't fire at all, even on starting fluid, you need to look at why you aren't getting spark.
So while looking under the hood for any visible abnormalities, I spotted two unplugged, loose wires. One to the right of the intake manifold (blue) one to the left of the alternator, really long wire(yellow end)
Do you know what any of these do?
Old Jun 15, 2021 | 04:32 PM
  #23
They gotta go somewhere. I am not real familiar with the 4.7 though.... So, no idea what they plug into. Check the wiring harness for any connectors just layin' about.
Old Jun 16, 2021 | 05:02 PM
  #24
Canadian Mechanic
Your thoughts on a crankshaft position sensor?
Old Jun 16, 2021 | 06:29 PM
  #25
If you are getting spark, the crank sensor is doing its job.
Old Jun 16, 2021 | 06:42 PM
  #26
Canadian Mechanic
So in your opinion, why do you think it idles for two seconds then dies?
Old Jun 16, 2021 | 09:07 PM
  #27
Well it stay running if you hold your foot on the gas a bit?
Old Jun 16, 2021 | 10:25 PM
  #28
Canadian Mechanic
No, nothing I've tried has worked so far
Old Jun 17, 2021 | 08:13 AM
  #29
What is fuel pressure doing? If it fires for a couple seconds, then it seems the sensors are working properly.... just something is forgetting what it is supposed to be doing...
Old Jun 17, 2021 | 08:29 AM
  #30
Canadian Mechanic
Fuel pressure is at 48, normal
