Transmission questions
Old May 27, 2021 | 02:56 PM
Plain Old Dave's Avatar
Plain Old Dave
Default Transmission questions
99 Dakota 2wd with 44RE and 318.
1. Slight shudder under mild tipin in forward and
reverse.
2. Sometimes when cold, I'll have to use extra gas
when backing up. No real RPM/MPH mismatch, really
more feeling like the brakes are on or the truck
is full.
Observations- fluid level is good. Fluid is
somewhat dark but still red (PO said he changed it
about 60k ago, and it looks like Mercon V with 60-
70k) but doesn't smell burnt. No trans heat light,
or check engine light. Shifts immediately into
Drive, very promptly into Reverse. No issues
driving.
Old May 28, 2021 | 03:41 AM
hidden1's Avatar
hidden1
Any codes?
Maybe overdrive goin out or sensorssensorsd similar issue an overdrive an spring was busted
Old May 28, 2021 | 09:53 AM
Plain Old Dave
Never had any light other than the classic ABS/Brakes. Need a new ABS module eventually. That's intermittent, though. Truck has done this since we got it just before Easter.
