Anyone know where an AC mode door can be located?
Old May 27, 2021 | 10:18 AM
bolt's Avatar
bolt
Default Anyone know where an AC mode door can be located?
Hey all. I just repaired a wrecked 2000 Dakota for my daughter's boyfriend, and I liked it so much I searched out and bought another rust-free 2002 R/T.
On the 2000, I have an AC Mode Door, (part number 4462687), with a broken axis shaft. It is broken on the top end where the rotation lever clips onto the shaft. The part has apparently been discontinued. I'd like to buy a replacement. Does anyone know where I could locate this specific part? (My other options are to try and pull one out of salvage, or repair the broken one I already have.)
Any guidance would be appreciated!
Thank you,
Lance
Old May 27, 2021 | 02:11 PM
I think there was a thread around here somewhere, that a member rebuilt his doors, to be a bit stronger than factory stock. Don't remember what year it was, or if it was a Dak, or Full-size... but, it'll be in the truck section here. Search *should* turn it up.
Old May 27, 2021 | 09:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you're sure of the part number you can get it here:]
4462687 mode door
Old May 27, 2021 | 09:34 PM
Dodgevity's Avatar
Dodgevity
Any of this work?
https://www.google.com/search?q=mode...4dUDCA4&uact=5
Old May 29, 2021 | 08:33 AM
98DAKAZ's Avatar
98DAKAZ
4462687 mode door
That's not the main door that's the defrost redirect door they usually never brake.
