Throttle Grind?
Old May 30, 2021 | 02:41 PM
Schooly's Avatar
Schooly
Default Throttle Grind?
Just purchased a 98 dakota slt, 4x4, v6 Experiencing a weird grind at 1 or 2 % throttle. Noise can be sustained by holding throttle, Usually happens while coasting. Cant seem to find anything relative online. Has anyone experienced this or have an idea of what it may be?
Old May 30, 2021 | 04:29 PM
Can you tell where the sound is coming from??
Old May 30, 2021 | 04:59 PM
Schooly's Avatar
Schooly
Its a bit hard to tell, definitely sounds like it's coming from the front end. The noise isn't exactly subtle. Hard to give you a more accurate description from the drivers seat. Does not seem to be affected by speed at all only rpm and a very small range. Coasting with light pressure on the pedal produces a constant loud grind
Old May 30, 2021 | 07:28 PM
Can you take a vid, with audio? Post at someplace like youtube, then link to it here.
Old Jun 2, 2021 | 02:05 AM
Schooly's Avatar
Schooly
Sorry about the delay, had her in for brakes today. Did my best to capture the audio.
