4.7 Jtech Cam Reluctor, Help Please!
Old Jun 11, 2021 | 11:36 AM
RamAir4's Avatar
RamAir4
Default 4.7 Jtech Cam Reluctor, Help Please!
I've purchased a rebuilt 4.7 and have installed the engine. I have no ignition. I know that the Jtech requires a 16 tooth tone ring. I'm just trying to find out what the window configuration is for the camshaft reluctor. I'm pretty sure that I was sold the wrong engine.
​​​​​​I Really need some assistance!
Old Jun 11, 2021 | 08:05 PM
00DakDan's Avatar
00DakDan
Section Moderator
If you can access the RH cam sprocket, if it's NGC it should be stamped. JTEC has no marking (OEM).
There are 8 sets of slots in the reluctors. CW from the keyway JTEC would be: 1,1,3,1,2,3,3,2
NGC would be: 1,3,1,2,2,3,2,1
Old Jun 18, 2021 | 11:51 PM
magnethead's Avatar
magnethead
3 PCM connectors is 16 teeth, 4 PCM connectors is 32 teeth. Visually the engines are identical.
Old Jun 19, 2021 | 09:57 AM
Murray Hill's Avatar
Murray Hill
Thanks so much. I didn't receive the correct engine. They sent an NGC, My PCM is a Jtech.
Old Jun 19, 2021 | 07:04 PM
magnethead's Avatar
magnethead
so both engines have 16 cam teeth, it's only the crank that changes 16/32? Good news to know!
