2001 Dakota 4.7l Engine rebuild
Old Jul 21, 2021 | 11:28 PM
Damn4.7Ldiditagain's Avatar
Damn4.7Ldiditagain
Default 2001 Dakota 4.7l Engine rebuild
Hello everyone.
I have my 2001 Dodge Dakota 4.7L AWD, 8th vin digit is "N", 16th tooth crank wheel with 109,000 miles on it.
The original engine threw a rod and had a knocking, so I figured I'd go find one at the junk yard with a bad tranny.
God was I wrong...
So 3 engine swaps later, I have this new 4.7l that has it's own issues. I have it broken down to the pistons, with the heads removed. The timing was bad and caused it to skip in the passenger cylinder head. 3 valves appear to have hit the pistons but only 1 looks really bad (Attached picture)
Im debating on replacing the timing, all cylinder valves that are bent and seats and head gaskets OR just doing a full rebuild. I'm tight funds and cant really afford the $1300 a machine shop would want, so I'd make do with what I have at home (which is a lot, I feel)
Will I be ok using these pistons and just doing the timing, gaskets and cylinders (replace the bent one) or should i do a rebuild?
I also wanted to know if anyone has success or failure using and ebay kit? Seems too good to be true on the prices, but I wasn't sure if anyone has had success.
Thank you in advance, everyone.
Old Jul 22, 2021 | 05:19 AM
98DAKAZ's Avatar
98DAKAZ
Never use any piston thats had a hit it could have a crack in it and or distorted.
Old Jul 22, 2021 | 02:50 PM
And that gouge in the piston will cause hot spots, which lead to pre-ignition, which can grenade the piston.....
