Resealing rear glass
Old Jul 25, 2021 | 06:49 PM
Dodgevity's Avatar
Dodgevity
Default Resealing rear glass
So I have a leak in the upper driver's side corner of my rear window. Eight years ago, I replaced the plain back glass with a slider unit from the junkyard and back then I used the 3M butyl rubber ribbon seal (listening to my cousin). Now I'm gonna have to do it again due to the leak, but I want to use urethane this time (the 3M stuff in the white tube). Anyone know if the urethane will stick to the butyl rubber or do I have to clean off every speck? It's still tacky when I touched it. The window separated from the seal for about a foot on the corner. I'm almost tempted to silicone the area and call it a day. Much less work.
PS: Bought one of those windshield removal tools (knife with pull handle) from harbor freight and now realize I should have gotten the wire type instead.
Old Jul 26, 2021 | 07:53 PM
wheily's Avatar
wheily
it will stick to the butel rubber (along with every thing it gets on) but will eventually leak there use to have to reseal windsheilds all the time that another shop installed with butel.a hair dryer and good putty nive will usaully take the butel rubber off
Old Jul 26, 2021 | 11:15 PM
ol' grouch's Avatar
ol' grouch
I've sealed several windows over the years with "flowable" silicone that wicks. It's real thin and will suck right in on some gaps. I've done about 5 and 4 worked really good. The 5th one got a rock and had to be replaced before I had a heavy rain to test it in.
Old Jul 27, 2021 | 12:01 AM
Dodgevity's Avatar
Dodgevity
Thanks, fellas. I removed the window this evening using this tool. Tomorrow I will clean up everything and hopefully get it all done.
Old Aug 1, 2021 | 09:59 PM
Dodgevity's Avatar
Dodgevity
Got it done. Not a fun job at all. Worth paying for, if anyone is wondering. Got things all ready to go and found the $30 tube of 3M urethane that I got from Advance, was f*king dried up. Couldn't squeeze out a drop. Checked mfg date and it was 2018, and that was their last tube lol. Got another tube hours later elsewhere and it was 2021.
Was able to do this by myself, no helper. The slider assembly is heavy but I dry fitted it using the dirt outline as a guide. LOL.... I then applied tape to top of cab and glass while in place. Flipped it over on cab, applied urethane to channel of cab (vs glass assembly), flipped it back down, minor adjustments, then locked the clips inside. The painters tape held the weight of the assembly in place. This was a lot harder and messier than I described, but the tape was a very good helper. Learnt it at youtube university. Now waiting on rain.
