Grinding Transfer case
Old Sep 30, 2021 | 11:19 PM
moparguy44's Avatar
moparguy44
Default Grinding Transfer case
2000 3.9l 4x4. NV231. If I shift the transfer case into 4lo it won't engage. The gears will just grind. I have to put the transmission into neutral and shut off the engine. It's the same when shifting back to high. Is this just wear or can it be adjusted?
Old Oct 1, 2021 | 09:42 AM
4 Lo isn't synchronized, so, you either have to shift FAST, or, do exactly what you did. I try and shift into 4 lo when moving VERY slowly. Less than 5 mph. Usually works.
