torsion bar lift? what and how?
RE: torsion bar lift? what and how?
Torsion bar lift is pretty simple. Do the same amount of turns on each side. Then make minor adjustments to get the same ground to fender clearance on each side. Drive it around a couple of miles, then recheck, and get it aligned. I would stick to 1-1.5 inches. Anything greater than two inches and you will prematurely wear front end parts.
Ok ill revice this post for a bit
So this is an interesting idea for me. Ive been thinking of getting 33x10.5 on my truck but i dont want them to rub as it is my only ride. But is there a was to jack up the back end this way? I saw that someone asked this already and that someone else said that 33s will fit in the rear. But my truck sits level as it is and i dont want it looking goofy with the nose in the air.
My other question is, can i tell if this has already been done before?
Thanks
Thanks
