2002 dakota standard cab 2wd
Old Jan 13, 2022 | 06:34 PM
roirp's Avatar
roirp
Default 2002 dakota standard cab 2wd
hello, my first time here. I am trying to order brake lines, and every place I am trying to order from. only say the lines are for 4wd. am wondering are they the same for 2wd. tks
Old Jan 14, 2022 | 01:50 AM
wheily's Avatar
wheily
mopar list 2 diffrent part numbers from 2wd ..and i noticed with any v8 engine it wont let select 2wd but if i put in 3.9 engine it gives a 2wd option but rockauto shows a 2 and 4x4
Old Jan 14, 2022 | 09:18 AM
roirp's Avatar
roirp
Tks Wheily. Will check rock auto.
Old Jan 14, 2022 | 10:38 AM
Which brake lines are you trying to find?
Old Jan 14, 2022 | 10:51 AM
ol' grouch's Avatar
ol' grouch
Except for the little ones going to the ABS pump, I usually cut my own. I often will add junction blocks with bleeders to snag any heat bubbles. With today's brake fluids, boiling isn't much of a factor, but old habits die hard.
Old Jan 14, 2022 | 11:28 AM
roirp's Avatar
roirp
Hey you , I am looking for the 2 rear brake lines on the axle. Tks.
Old Jan 14, 2022 | 12:18 PM
Go to your local parts store, and just pick up some of their pre-cut lines. They are straight, so, you will need to bend them a bit yourself. They are a couple bucks each, as opposed to what they want for pre-bent lines, plus shipping, etc. You can bend the lines by hand. It's that easy. I have never purchased pre-bent lines for any brake job I have done.
