Stuck in first gear solution
Old Dec 29, 2021 | 07:29 PM
r_bgr_h_m's Avatar
r_bgr_h_m
Default Stuck in first gear solution
Transmission, 44re, stuck in first gear with no codes. I'm posting my solution here because it was the first link that came up when I searched for my problem.
I have a 1999 Dakota with 5.2l V8. Transmission was running in limp mode with codes 753 and 1765 when I got the truck. I unplugged the computer to reset it and the codes didn't return. As soon as I pulled the transmission relay those two codes came up again.
Reset the computer again and everything seemed to be working. The next day I drove to work and the tranny got stuck in first gear with no codes. Long story short...the TV cable has a plastic shield that slides over a metal tube at the arm on the transmission. A stickiness built up on the sliding connection. I squirted some silicon lube on there and presto....transmission back to normal. This cable forces the transmission to drop gears, hence why mine was stuck in first gear .. and the engine thought everything was working as expected (no codes). I highly advise anyone to lubricate this cable and arm at the transmission before ever making any adjustments to it.
