ABS and Brake Warning on at the same time
Old Feb 28, 2022 | 07:08 PM
Henrykjr's Avatar
Henrykjr
How would I know? is there a similar wheel speed sensor on the front ?
Interestingly I went to have the codes wiped out and the abs / brake light popped off for about 10 seconds. I was briefy happy.
In addition a put a new speed sensor in the transmisison and now it wont shift correctly. Gee whiz!
HK
Old Feb 28, 2022 | 07:57 PM
Henrykjr's Avatar
Henrykjr
I just confirmed 4 wheel antilock brakes
HK
Old Feb 28, 2022 | 08:49 PM
ol' grouch's Avatar
ol' grouch
HK
A good reader that reads ABS should tell you if you have a bad sensor. There is usually a sensor at each wheel on 4 wheel ABS.
Old Mar 1, 2022 | 01:33 AM
hidden1's Avatar
hidden1
Were you getting a obd2[ not abs] speed sensor code? If not ,put the original back after cleaning up the end.
The abs tester will specify which one may be bad.It will know if you have 2 or 4 on testing.
Old Mar 9, 2022 | 10:24 PM
Henrykjr's Avatar
Henrykjr
Here is the link to what they are rebuilding:
https://www.automotivecircuitsolutio...dakota~yr_2002
HK
