Headlight not working
Old Apr 7, 2022 | 10:10 PM
Sitruc's Avatar
Sitruc
Default Headlight not working
I have a 2000 Dodge Dekoda and the headlights aren’t working. I have new bulbs in the high berms work and I replaced the switch box but I don’t have any light
Old Apr 12, 2022 | 01:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
The high beams work normally or only in "pass to flash"?
Each headlight has it's own fuse and is supplied a constant 12v. The ground side is switched.
Check the ground G200 for the headlight switch. It'll be the black with orange striped wire.
Both high and low beams share the G200 ground point - you'll see multiple wires on it.
G200 is located under the instrument panel on the left side, near the dash pivot point. It's a heavy 16 gauge black wire.
