P0753 and P1765
Old Apr 16, 2022 | 07:33 PM
byronpen's Avatar
byronpen
Default P0753 and P1765
After shop did a motor swap, my trans started to throw P0753 and P1765 codes and now is in limp mode.
I can Put the truck in 1st and 2nd no issue, When in drive it doesn't shift thur the gears.
I have done the ECU Pin 30 grounding trick, still nothing any other Ideas
Old Apr 16, 2022 | 08:52 PM
supadoom's Avatar
supadoom
I wonder if they broke/pinched a wire while moving the harness around. Not sure which wire you would need to check but its not receiving voltage on the control solenoid.
