Blower motor resistor on 2004 Dakota
Old Jan 1, 2006 | 11:38 PM
KMYR's Avatar
KMYR
Default Blower motor resistor on 2004 Dakota
Can anyone tell me where to locate the Blower motor resistor on a 2004 Dakota. Only working on high. thanks in advance!
Old Jan 7, 2006 | 02:40 AM
stev98312's Avatar
stev98312
Default RE: Blower motor resistor on 2004 Dakota
A flashlight will be helpful. Go to the passenger side and look up under the dash panel. You should be able to find the blower motor easy enough. Go inboard a bit and you will find a bundle of wires going up into the housing. That's it. As I recall, it takes 5/16" (8mm) socket. There's two bolts, and when they're out, the thing just drops into your hands.
I was reading so much about these resistor board failures, I took mine out and attached a heat sink to it.
