You have to unthread the adjuster I believe. It's just a big spring. Take the nut and spring off, and the assembly comes off. It's up at the front of the cab.
I am taking the cables loose at the rear, somewhere near the left rear tire. Or I can take them loose on the brake backing plate, but don't really want to go there. Never had good luck taking drum brakes apart. Apart is easy- getting it all back together is the hard part!
Steve
won't quite work that way. They are crimped together/not servicable at that end. Have to unhook the cables from the brake drum actuators, or take them loose at the pedal. No in-between.
