P0463 - Solution?
Old Jan 4, 2006 | 06:15 PM
Millerlite1217's Avatar
Millerlite1217
Default P0463 - Solution?
I have had my dakota for about 4 months now and am very happy with it but about 3 weeks ago my gas needle started acting funny. I did the procedure to get any error codes by turning the key 3 times and this is the code it gave me - (463 Fuel level sender voltage wrong). I was wondering if anybody has had this problem and how it was solved. The only solution I can come up with is a new fuel sending unit and pump, b/c I beleive they are one unit. I would like to avoid this if possible . Thanks ahead for any help. By the way my truck is a 2001 4.7 v8 Quad Cab with A/T and 65,000 miles.
Old Jan 4, 2006 | 08:31 PM
Joelzy's Avatar
Joelzy
Default RE: P0463 - Solution?
when i bought my dakota the guy told me that the gas gauge doesnt work anymore and just to use the trip meter to know when im low. That only lasted a while. i started using better gas and cleaners here and there and eventually it started working on its own. every once in a while it will drop to empty and beep at me but it will jump right back up after a second. so maybe try something along those lines. i didnt have a problem using the trip meter but it sort of fixed itself. hope thats some kind of help to you
Old Jan 5, 2006 | 01:59 PM
Millerlite1217
Thanks for the reply Joelzy. Mine is the same way, it works from full to about 1/8th below full and from below 1/2 a tank almost to empty and I've been using the trip just like you said. I was just wondering if there was any kind of quick easy fix that someone had found. Thanks.
-Millerlite
Old Jan 5, 2006 | 04:24 PM
Millerlite1217
bump
