Head gasket
Old Apr 2, 2023 | 07:11 AM
Shira's Avatar
Shira
Default Head gasket
Ok, so I have been working on the head gasket to my 97 3.9L V6 Dodge dakota 2 wd. 5 spd. Anyway. We are down to the heads and need to remove the valve springs and rods. Is there a way to remove these without the valve spring tool? Can someone please provide me a step by step process of doing this. This is the vital part, I know.
I am not the mechanic, I am paying my neighbor to do this for me. After parts and labor, I am pretty spent on money to rent the tool. If anyone can help me with infos, I would greatly appreciate it.
thank you
Old Apr 2, 2023 | 10:13 AM
Need the tool to remove valve springs. If the heads are still on the motor, you are going to want to do something to keep them from falling into the cylinders as well. With the heads off, its a non-issue. Valve springs don't need to come off to pull the heads. Pull the rockers, and pushrods though. (and keep them in the proper order. You want them to go back into the same place they came out of.)
