'98 pcv confusion
Old May 28, 2023 | 05:26 PM
98IntenseBlueCC's Avatar
98IntenseBlueCC
Default '98 pcv confusion
Okay, so when looking up the parts, I'm getting conflicting results. '98 5.2, pcv in passenger valve cover, I need a new pcv and the matching grommet. Does anybody know what the Mopar original part numbers were so I can cross reference? When I look up the parts I get various results, all saying "this will fit".
Old May 28, 2023 | 07:19 PM
You should just get the PCV valve from the dealer, last I checked, it was less than 10 bucks, and it's actually the correct flow rate.
Old May 28, 2023 | 08:02 PM
98IntenseBlueCC
Im thinking I'll do that, stick to Mopar especially since the grommet and valve aren't that expensive.
One more question, is the 90° elbow on the other valve cover that is connected to the "hat" on the throttle body just an elbow? Is there nothing inside it?
Old May 28, 2023 | 09:57 PM
Just an elbow. PCV system draws air from the box.
Old May 28, 2023 | 10:12 PM
98IntenseBlueCC
Thank you so much for all the help! I found and ordered the pcv valve and the grommets, all Mopar.
