Swap 5.9 to 3.9
Old Jun 2, 2023 | 11:46 AM
Swapper@$$'s Avatar
Swapper@$$
Default Swap 5.9 to 3.9
Ok I ha
be a 00 Dak manual . And a 01 dran. AutoI need to know what I need to do to to drop the 3.9 where the 5.9 is .. I know I know. But I'm broke and I have this to work with. My question. Really. Is will I need a feff. Flex plate or is it possible to use the 5.9 one ?? I'm thinking that's the only part I may need to get ?? And computer ?? 8 to 6 . Will the comp. Need prog.?? ​​​​
Old Jun 2, 2023 | 12:34 PM
Definitely need a different flex plate. The 5.9 is externally balanced... 3.9 is not.
Will have to have the computer re-programmed for the 3.9. Crank sensor signal is different, and there are two less cylinders..... V-8 programming won't run the six at all. You might be better off finding another 5.9 to drop in there, probably end up being cheaper.......
Old Jun 4, 2023 | 02:23 PM
magnethead's Avatar
magnethead
What HeyYou said. Graba. $1000 engine from a junkyard. you'll be spending at least that for a PCM, flexplate, programming, etc.
