Door sensor?
Old Jan 6, 2006 | 07:27 AM
bluegrasshole's Avatar
bluegrasshole
Default Door sensor?
Does anyone know where the door sensor is located? I am thinking it is magnetic and located in the door latch assembaly... I am having problems with my warning bell sounding off after truck is turned off... Any one have any experiance with these or any ideas? Thanks... 2001 4.7 Dak quad...
Old Jan 7, 2006 | 02:15 AM
stev98312's Avatar
stev98312
Default RE: Door sensor?
The door sensor is at the latching mechanism within the door structure.
Old Jan 7, 2006 | 02:32 AM
bluegrasshole
Any idea if it is magnetic or a switch? And thanks for the help friend!!
ORIGINAL: stev98312
Old Jan 7, 2006 | 07:53 PM
stev98312's Avatar
stev98312
Looking at the schematics, it appears to be a mechanical switch.
Here's some words from my FSM
"The door ajar switches are integral to the door latches on each door."
"The switches close a path to ground for the Central Timer Module (CTM) when a door is opened."
"The door ajar switches cannot be repaired and, if faulty or damaged, the door latch unit must be replaced."
Old Jan 8, 2006 | 03:16 AM
bluegrasshole
Hey, thanks very much stev98312 for the info!! Looks like she is off to the shop... Or is this a pretty easy repair? Thanks again!!
