What could disable Blower and AC compressor at the same time
Old Aug 9, 2023 | 06:49 PM
carson1993's Avatar
carson1993
Default Had to Abandon the Resistor replacement, had to use the truck AC or not
Originally Posted by carson1993
Thank You!!!
I have the service manual, i'll try to figure it out. Thank You!!
BHad to abandon
I was trying to get tp the resistor under the dash, couldn't pull that off, Buttoned everything back up and the Compressor started working. The Fan still isn't working, I had to order a puller to get the Whipper arms off to try to get to the resistor from that way. Any Thoughts? I could reunn the fan with a +/- Power probe so I have to assume the Blower is OK.
Old Aug 9, 2023 | 08:08 PM
Does the fan work on ANY speed?
Old Aug 14, 2023 | 01:48 PM
ol' grouch's Avatar
ol' grouch
BHad to abandon
I think the blower resistor is at the top of the dash and you might be able to access it from the top when you remove the panel by the windshield.
Old Aug 18, 2023 | 02:05 PM
carson1993's Avatar
carson1993
Fan doesn't work at any speed.
Old Aug 18, 2023 | 02:06 PM
carson1993's Avatar
carson1993
Got to the resistor pack on the firewall engine side.
Old Aug 18, 2023 | 04:39 PM
Are you getting power TO the blower motor?
Old Aug 19, 2023 | 04:24 PM
carson1993's Avatar
carson1993
Default Found something
After Checking and replacing Resistor pack, Blower motor, it started working out of the blue, then quit again. I saw a cluster of wires and a connector to the left of the glove box opening I moved the around and every thing started working. It's 113F here today I cant stay out very long to work on it, I'll get up before sunup in the morning and see what the fix needs to be
Old Aug 19, 2023 | 05:15 PM
Yeah, no point cooking yourself. Go back in the A/C. Worry about it later.
Old Aug 20, 2023 | 01:17 PM
carson1993's Avatar
carson1993
Everything is working BUT When I try to secure the Dash snug every thing stops, give it slack and all works again, I'm going to just button it up with some slack in the dash and fight another day.
Old Aug 20, 2023 | 03:22 PM
carson1993's Avatar
carson1993
The problem all along was intermittent loss of ground to days. Seems to be fixed now.
