Dakota runs like crap after 360 swap
Old Oct 5, 2023 | 06:39 AM
Is the two wire temp sensor plugged in?
Old Oct 5, 2023 | 07:47 AM
Brukota's Avatar
Brukota
Yes it is
Old Oct 5, 2023 | 01:59 PM
cwkerr007's Avatar
cwkerr007
ok what are you doing when you have checked the problems with the plugs are you replacing them or cleaning them ??? and another obvious thing they are the right plugs ??????? cause if the problem has been solved by your checks the plugs won't clean themselves not in the short time you are running it. I'm not good at spelling the way i speak so don't get upset i just wanna help ya and find your problem so it don't happen to me , so if my questions are not helping just ignore me . I mean no harm here
Old Oct 5, 2023 | 02:01 PM
cwkerr007's Avatar
cwkerr007
cause i'm sure you're frustrated at this piont!! I would be!
Old Oct 5, 2023 | 02:08 PM
cwkerr007's Avatar
cwkerr007
do you have a noid light??
Old Oct 5, 2023 | 02:48 PM
Brukota's Avatar
Brukota
I checked the plugs, all dry and black so i replaced them
and nothing changed
Old Oct 6, 2023 | 06:49 AM
Do you have a scanner you can plug in that will read live data?
Old Oct 6, 2023 | 10:31 AM
Brukota's Avatar
Brukota
I have an hp tuners module
Old Oct 7, 2023 | 08:58 AM
Plug it in, with the engine stone cold, ignition on, engine off, see what the PCM thinks coolant temp is.
Old Oct 7, 2023 | 10:37 AM
Brukota's Avatar
Brukota
Thank you ill check, also i plan to check vaccum.
