Rear differential
Old Oct 9, 2023 | 07:27 PM
Mr.Doug's Avatar
Mr.Doug
Default Rear differential
Question: I have a 2000 Dakota with a 10 bolt, 8.25" rear end. 3.55 ratio. The truck sat for an unknown amount of time. I bought it last November with 78k miles. I recently had the muffler replaced and they found that the pumpkin was dry. We put oil in it, but it sounds like a diesel turbo winding up when driven. My question is, would it be more cost effective but still correct the problem to rebuild the differential with a rebuild kit, or should I spend the big bucks on a replacement? Could the problem be something else entirely?
Old Oct 9, 2023 | 11:07 PM
magnethead's Avatar
magnethead
Two ways you can go.
Is it 2 or 4 wheel drive?
2 wheel drive 8.25's should be plentiful in junkyards, and will likely be cheaper than a gear replacement. Main issue is that some years had a traditional yoke and some had a companion flange.
4 wheel drive 8.25's will be harder to find.
2 and 4 wheel drive 9.25's will be hit and miss to find, but would be a good junkyard upgrade.
The Dakota axle's leaf spring perches are 2" different from the ones on a durango, so they are not interchangable. The 8.25 from an XJ also does not work as I recall.
Otherwise, budget $5-600 on replacing the gears.
Old Oct 10, 2023 | 05:15 AM
Mr.Doug's Avatar
Mr.Doug
[QUOTE=magnethead;3575191]Two ways you can go.
Sorry, should have said in the description. It is 4WD.
I have only found 2 on the 'net so far, one is in the mid 400 range, the other is about 700.
I have seen rebuild kits for about 200, and those I don't have to have shipped cross country, hence the question.
Old Oct 10, 2023 | 08:38 AM
Rebuild kits are generally just bearings and seals, if your gears are worn, that won't help. JUST the gears can cost north of 500 bucks...... replacing the entire axle with a used one is almost always cheapest.
Old Oct 10, 2023 | 09:12 PM
00t444e's Avatar
00t444e
You can also use a 9.25 out of a 4x4 Dakota as long as it has 3.55 gears.
