'02 Dakota climate control question
Old Feb 26, 2024 | 01:09 PM
Craig L's Avatar
Craig L
Default '02 Dakota climate control question
The climate control developed the following issue, Fan blows, all speeds but controls for the temp and direction of heat, Def, floor etc does not work.
Is it a bad control unit in the dash or possibly something else?
Old Feb 26, 2024 | 03:19 PM
Check for a broken vacuum line under the hood.
Old Feb 26, 2024 | 03:33 PM
Craig L's Avatar
Craig L
Not the issue i, the AC and rear defrost buttons are non functional as well
Old Feb 26, 2024 | 03:46 PM
Correct. Everything on that appears to be electric.... Check fuse 25 in the fuse block on the side of the dash. Should be a 10 amp.
