5.9 heads on a 5.2
Old Apr 8, 2024 | 09:47 AM
5.2 Braxton's Avatar
5.2 Braxton
Default 5.9 heads on a 5.2
Hello, I have a 1997 dodge Dakota with the 5.2 318. I was wondering what I would have too do to swap 5.9 heads over to a 5.2 (both magnums). Thank you in advance for your help
Old Apr 8, 2024 | 04:48 PM
Is there a difference in the heads???? So far as I know, they are interchangeable.
Old Apr 8, 2024 | 09:32 PM
magnethead's Avatar
magnethead
No difference in heads. both 1.92 x 1.60
Old Apr 9, 2024 | 01:14 PM
WestCoast_Texan's Avatar
WestCoast_Texan
Is there an intended benefit to the swap? I don't know much about the differences between the 318 and the 360 but if the heads are interchangeable is there a point to the swap? Or is this because your heads are damaged and you happen to have some 360 heads?
Old Apr 9, 2024 | 05:59 PM
So far as I know, both engines use the same heads..... so, zero difference.
