Misfires
Old Apr 19, 2024 | 06:25 PM
1MoparLuvr's Avatar
1MoparLuvr
Default Misfires
I have a 99 Dakota with the 5.2L magnum (250k miles)that I just picked up a couple months ago. First thing I did was install new plugs(Autolite 5224) serpentine belt and air filter. Ran great with no codes. Recently it threw a P0303 so I installed new plug wires, then new cap and rotor. I swapped #1 and #3 injectors to see if it was the injector but I still get a P0303 code. #3 cylinder has 120 psi and I have no vacuum in the crankcase so it can't be the valley pan gasket. There is a noticeable mis coming from the exhaust pipe and at idle and the spark plug is grey ashen which tells me it's running Lean.
Any suggestions where to go next?
Old Apr 19, 2024 | 08:49 PM
Broke this out, and moved it to the correct section. Don't hijack someone elses thread.
Old Apr 19, 2024 | 09:33 PM
1MoparLuvr's Avatar
1MoparLuvr
Got it. Thanks.
Old Apr 20, 2024 | 05:00 PM
magnethead's Avatar
magnethead
Did you clear all codes/reset the computer when you swapped injectors?
Have you put a noid light on the injector to verify that the injector is being commanded to fire?
Old Apr 20, 2024 | 11:19 PM
1MoparLuvr's Avatar
1MoparLuvr
Codes were cleared. All injectors are firing. My first thought was it may be a small valley pan leak directly over #3 but there is no oil fouling on the plug.
Old Apr 22, 2024 | 07:31 PM
magnethead's Avatar
magnethead
If it was an issue with the crank sensor, oxygen sensor, or a cylinder head ground strap, it would be multiple cylinders affected.
1-8-4-3-6-5-7-2 the same hole in the crank sensor fires cylinders 3 and 2.
The driver-side upstream oxygen sensor detects misfires for 1,3,5,7 (there are no knock sensors - misfires are 100% done by oxygen sensors)
A head ground issue would also affect 1,3,5,7 the same.
The only thing that would affect #3 only would be fuel or air. Since it's a common rail system & you already swapped injectors, I'd be inclined to think it's an issue between the #3 driver in the PCM and the #3 injector plug causing a lean spray, or an issue with the valvetrain on that cylinder preventing proper intake/exhaust flow. Again, the oxygen sensor is what detects misfires, so an issue with exhaust delivery will get marked as a misfire.
Old Apr 22, 2024 | 07:50 PM
1MoparLuvr's Avatar
1MoparLuvr
When I get a chance I'll do a leak down check. I usually don't bother if it has good compression but I'm running out of ideas. If there's an issue with the ECU not sending enough fuel I doubt I can find anyone who can fix that around here.
