Bigger throttle body?
Old Apr 25, 2024 | 11:16 PM
5.2 Braxton's Avatar
5.2 Braxton
Default Bigger throttle body?
Hello, I have a 1997 dodge Dakota sport with the 5.2 318 magnum. I’ve been tearing it down which now is too the block. Im putting a .488"/.501" comp cam, longer push rods, melling lifters, shorty headers, and a set 5.9 magnum heads on it. I was wondering what is the biggest throttle body I could put on it without getting bigger injectors? And is a bigger throttle body even necessary, and do I need bigger injectors with these mods already as it stands.
thank you for the help in advance
Old Apr 26, 2024 | 08:21 PM
magnethead's Avatar
magnethead
the stock 49mm 2bbl is fine for naturally aspirated and is limited by the beer keg manifold. Usually switching to an M1 or airgap manifold will call for a swap to a 52mm TB and thats about it, several supercharged trucks have kept the 52mm TB. I'm one of very few that went to a 4 barrel.
