Electrical issues
Old Jul 9, 2024 | 08:07 PM
Kenneth Vaughn's Avatar
Kenneth Vaughn
Default Electrical issues
Not really sure if I have second or third generation but I do need help please. I bought this truck a few months ago and had nothing but trouble so far. But now it seems that I have half my fuse box working. On some of my fusses my test light shows red and on others it reads green. I have traced it down to find out that my alternator has a red light reading coming from it. So I disconnected it completely but still attached to truck. I still get a red light reading but if I disconnect it from the fuse box it's self then I get all green only on fuses. I don't understand. Doesn't the red light mean it has a short? The reason that I am in the fuse box is because my OD in the transmission has no power and running in 2-and 3 gear. It won't shift. Please help
Old Jul 9, 2024 | 08:09 PM
Green means the test light sees power. Red means it sees a ground. If you are poking something that shouldn't go to ground, need to find out why it does.
Old Jul 9, 2024 | 08:11 PM
Kenneth Vaughn
So it's ok for the fuses to read red?
Old Jul 9, 2024 | 08:15 PM
Some should be hot at all times.... Others will be hot with ignition on. Depending on how you are testing..... that *might* be correct, or not...... Hard to say from here.
