Engine codes
Old Mar 27, 2025 | 02:25 PM
aaronmeier3@yahoo.com's Avatar
Default Engine codes
Got a p0051 p0422 p0455 I will take anything you got ! Do have the 4.7 .
Old Mar 27, 2025 | 02:46 PM
p0455 Large leak in the evap system. Fix this one first, clear codes, see what comes back.
Old Mar 28, 2025 | 08:12 PM
Would any of these codes cause a no fuel pressure problem ?
Old Mar 28, 2025 | 08:20 PM
Only if the O2 heater circuit gets power from the same source as the fuel pump..... So far as I know, the two circuits are completely separate. Diagnose no fuel pressure as a separate issue.
Old Mar 29, 2025 | 06:03 PM
Got the Evap codes gone now just the 0051
any tips
Old Mar 29, 2025 | 08:40 PM
Don't recall, but, have you swapped out the sensor?
Old Mar 29, 2025 | 09:51 PM
The o2 sensor ? No
Old Mar 29, 2025 | 11:04 PM
Don't suppose you can see what heater circuit voltage is by any chance????
Old Mar 30, 2025 | 10:13 AM
How do I check that ? Do I need to meter something or is that something seen on scanner with live data !
Old Mar 30, 2025 | 10:16 AM
Scanner *might* be able to read it.... Just depends on the scanner.
