Instrument cluster and ignition problem?
Old May 1, 2025 | 10:38 AM
Jmk841's Avatar
Jmk841
New Member
Default Instrument cluster and ignition problem?
2000 Dodge Dakota 4.7 instrument cluster not working gauge is not working lights not working turn signal indicator and bright indicator do work. When I turn my ignition switch from run to to on or off my car sounds like it's starting and turning itself off over and over again until I take the key out. Used to have occasionally no bus on odometer and occasionally RPMs and speedometer reader would drop to nothing while driving before this happened.
Old May 1, 2025 | 12:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
When you say "sounds like it's starting" do you mean cranking over with the starter?
Could be an ignition switch issue. The ignition switch trips a relay to power the starter.
Do you have a tilt wheel? Some people have had issues with wires getting damaged over the years.
Old May 1, 2025 | 02:12 PM
Jmk841's Avatar
Jmk841
New Member
Yes I do have a tilt steering wheel. I know it more sounds like revving up and down but like high revving like when you first started type of stuff almost like it wants to run but then it just dies when the keys off unless I pull it out of the ignition
Old May 1, 2025 | 02:51 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'd check the wires and ignition switch.
I attached the pinout from the switch.
File Type: pdf
Old May 3, 2025 | 03:55 PM
Jmk841's Avatar
Jmk841
New Member
Checked them and replaced switch still have no cluster
Old May 6, 2025 | 04:18 PM
Jmk841's Avatar
Jmk841
New Member
Default Weird
After a few days of car having security and starting issues after replacing the switch both have vanished and my gauges now work is this normal? At first they didn't work for almost 4 days and it was having issues starting now it is fine.
