Idiot waterpump-timing chain
Old Jul 29, 2025 | 07:20 AM
Aross5566's Avatar
Aross5566
Default Idiot waterpump-timing chain
Got a 98 5.2 dakota , replaced waterpump and like a idiot didn't pay attention to bolt locations and ran a long one in with a impact ...busting the waterpump,timing chain cover and cam gear . So I get to do the timing chain , I was wondering since I had moved the crank shaft getting things off if I can still just line my timing dots up and go or if its possible to get 180 out . Any help is appreciated
Old Jul 29, 2025 | 09:32 AM
How far did you move the crankshaft? IF only a little bit, just align the dots, and call it a day. If a lot..... Put number 1 at TDC in firing position, make sure the distributor rotor is pointed in the right spot, and put it back together.
Old Jul 29, 2025 | 10:37 AM
ol' grouch's Avatar
ol' grouch
You probably just moved it a little bit. Just realign the marks and you should be fine.
For future reference, I save old small boxes and sheets of cardboard and make a map of where the bolts go. Cut a small slot and use the new gasket to make an outline of the pump or other part you're installing. Put each bolt in the corresponding slot. It keeps them in the proper place and they also don't roll away on you. As many times as I've replaced water pumps and such, it's still a handy habit to get into.
Old Jul 30, 2025 | 06:52 AM
Aross5566's Avatar
Aross5566
Just a bit when taking fan clutch and all off , that's exactly what I did . Went and found which bolt goes where and made a cardboard holder for when parts get here I don't do that again like a moron .
Old Jul 30, 2025 | 11:14 AM
ol' grouch's Avatar
ol' grouch
Learning does not make you a moron. Doing it repeatedly is different. Otherwise, it's just getting experience. Over the years I've done a lot of things, thta in hindsight were not the best course of action.
Old Jul 30, 2025 | 12:05 PM
Dodgevity's Avatar
Dodgevity
I assume you didn't run it after this, but if you did, check for coolant in the oil.
Old Aug 1, 2025 | 01:04 PM
Aross5566's Avatar
Aross5566
I didn't but gonna change all oil any way
Old Aug 1, 2025 | 01:05 PM
Aross5566's Avatar
Aross5566
Finally got all my parts , once I get timing chain back on . Is there a way to make sure im OK before turning it on?
Old Aug 1, 2025 | 01:47 PM
Just make sure things are set right..... Gears are dot to dot, and distributor is pointing at the correct cylinder.... Which I *think* is going to be number 6 when the gears are dot to dot.....
Old Aug 1, 2025 | 07:00 PM
Aross5566's Avatar
Aross5566
gears are dot to dot and distributor is point at 6 . should be good right?
