AC...heater.. radio does not work
Old Aug 24, 2025 | 08:36 PM
Kota1987's Avatar
Kota1987
Default AC...heater.. radio does not work
I got a 2000 Dodge Dakota 4.7 the nothing on the dashboard on the heat or AC and radio does not work. Got the truck non running so don't know much about it. Just know that doesn't work and is there a fuse for it could someone tell me the napa model number I would need
Old Aug 24, 2025 | 09:17 PM
dodgetruck2's Avatar
dodgetruck2
Is there more information? I mean when you turn the key nothing happens anywhere? Bad connections? Battery? Whats the previous story, owner parked it running 10 years ago and now it doesn't? Ran yesteryday doesn't today?
Old Aug 24, 2025 | 09:39 PM
Kota1987's Avatar
Kota1987
Don't know how long it was sitting but starts and run. The only problem is the climate control nothing on it works nor does the radio. Everything else works on the truck
Old Aug 24, 2025 | 09:50 PM
dodgetruck2
I believe there is an HVAC fuse, could also check the IOD fuse
Old Aug 24, 2025 | 09:55 PM
Kota1987's Avatar
Kota1987
Do you know where that relay is at?
Old Aug 24, 2025 | 10:08 PM
dodgetruck2
both fuses should be located in the panel in the left side of the dash, in the door jamb opening
