Ac problems!!! New compressor,condenser,dryer
Old Jul 3, 2025 | 01:57 AM
98southla's Avatar
98southla
Default Ac problems!!! New compressor,condenser,dryer
7 days ago i replaced my compressor with a new one, charged it and everything was fine for about a week. Stop cooling out the blue so i pulled a vacuum to see if it had leaks and no leaks. Charged it back on. And the compressor worked for 10 seconds n stopped. Got 12 volts at the hi n low switches n the compressor itself but still wont kick on n cool. Do i replace both the hi n low switches? Any help would be greatly appreciated.
Old Jul 3, 2025 | 04:20 AM
Moparite's Avatar
Moparite
If you have power at the compressor and it's not coming on it's either a bad coil or worn clutch.
Old Jul 5, 2025 | 02:59 PM
98southla's Avatar
98southla
Default Brand new compressor, clutch n coil
all that brand new and it worked fine for a week then stopped. It come on fkr a few seconds n stop. I think its one of the pressure switches
Old Jul 5, 2025 | 03:29 PM
Put gauges on it, see what pressures are actually doing.
Old Jul 6, 2025 | 10:51 PM
98southla's Avatar
98southla
Default I did n my low side id high as hell
After pulling the vacuum again n recharging it worked for a minute maybe 2 n after the compressor wouldn’t stay on the low side was very high. I just put new pressure switches on today and same thing will come on just for a 5-6 seconds and back off. Im
stomped here.
Old Jul 7, 2025 | 06:39 AM
Moparite's Avatar
Moparite
What are the pressures when it kicks on?
Old Aug 12, 2025 | 03:28 AM
98southla's Avatar
98southla
50 lo n 150 hi
Old Aug 15, 2025 | 04:39 PM
00DakDan's Avatar
00DakDan
Section Moderator
If it's running only 5-6 seconds you won't get a good idea of the pressures.
Jump out the switches to eliminate them. Make sure you have 12v to the clutch - and a good ground.
Old Aug 15, 2025 | 05:58 PM
The pressures likely are WHY the compressor is cutting out..... I would at least want to make sure that is NOT the case before bypassing switches......
Old Aug 16, 2025 | 08:45 AM
ol' grouch's Avatar
ol' grouch
Did you replace the orifice tube? It might be stopped up. Usually one comes with a new condenser but they can be lots of fun to get the old one out. I'd also jumper the safety switch to see if that is the probleme.
