2004 Dakota No Start
My Dakota was running fine up until a couple of weeks ago when the battery died. Replaced the battery and now it’s dead when I turn the key. All other electrical is working fine except for the front dome light. I’d think it was the starter relay if it wasn’t for the dome light being out. Before I start replacing fuses and relays at random, anyone have any suggestions?
Thanks, that’s a good suggestion. I tried tapping on the starter, but it didn’t help. (Heck, in the course of trying to run this problem down, I’ve probably tapped on every component at some point). I should have been clearer when I said “dead”. Turning the key lights up the dash, but there’s no click or any other sign that the motor knows it’s supposed to do anything. The only visible signals that something is up is that the shifter position indicator endlessly cycles though all the positions, I intermittently get “no bus” on the error/mileage display, my OBD2 scanner won’t connect, and the dome light that I mentioned. I had someone with more experience look at it and he thought maybe lightning had struck nearby and the ECU might have been fried. I found a cheap used ECU online and have ordered it to see if that makes a difference, but it hadn’t yet arrived. If that makes a difference I’ll post. I sure miss the days when a truck was a motor, body, and wheels and not a computer.
