PCV Valve discontinued
Old Nov 23, 2025 | 04:42 PM
I think there is an updated number..... any vehicle that used the 3.9 will also use the same PCV valve..... So, dodge trucks, dakota/durango, and heaven only knows what else......
Old Nov 23, 2025 | 10:18 PM
Dodgevity's Avatar
Dodgevity
Exactly. The old part number has been superseded by....
5175352AA
Search on that and i'm sure you'll find it. Get the Mopar part.
Old Nov 24, 2025 | 01:49 AM
wizard6733's Avatar
wizard6733
5175352AA
Looks like rock auto has it...thanks for all the help
Old Dec 2, 2025 | 11:23 PM
hidden1's Avatar
hidden1
Take a look under the truck at the oil drain plug area an transmission for a tiny tiny wet point..the 2 piece seal can leak near there too an only as your driving does it leak.But I agree that the plenum can be a factor. How do the plugs look ? I got a OEM PCV at the dealer-they cross referenced to the ram with similar motor .Keep us posted I'm curious where the oil has been going too .
Old Dec 6, 2025 | 03:31 PM
wizard6733's Avatar
wizard6733
Well im waiting for the PCV valve I posted above to come in from Rock Auto. My OEM Hose for the PCV was split a little where it goes into the intake so I put some ultra black permatex on it and let it sit for a day or so. I check it again today and its exactly between full and add so Im guessing a half quart low. I didnt fill it back up this time since its still in the safe area. We have a bunch of snow and ice right now so Im unable to pull the spark plugs out but I didnt see any oil on the oil plug. The condition of the oil is really good, not black at all but sorta like a honey/syrup color and it doesnt look like any antifreeze is in it and the truck runs perfect so Im hoping its the PCV. Right now it has a duralast PCV i put in it back in august but I read its better to use the Mopar PCV so thats what im getting in the mail. Ill kee you updated...thanks for the reply
Old Dec 7, 2025 | 05:32 AM
Dodgevity's Avatar
Dodgevity
I must've misread your initial post when I said " Losing that much oil, you have to see something somewhere." I was thinking "week" when you said you lost half a quart a month. Not as bad but still not negligible. From my experience, I don't think the PCV valve will have you losing that much oil. I second getting under the truck and checking for leaks.
Old Dec 7, 2025 | 09:53 AM
I have had engines leak around the valve covers, and the oil would burn off on the exhaust manifolds..... no smoke, but, losing oil nonetheless.
Old Dec 7, 2025 | 01:06 PM
Dodgevity's Avatar
Dodgevity
Yep, there are a million ways to lose oil. There's no use in guessing, at least not till you've ruled out the basics.
Old Dec 14, 2025 | 03:03 AM
hidden1's Avatar
hidden1
Yes ,or try that additive,you put in the oil, that shows you with a light ,where the oil is leaking from ...
