backfiring
Old Jan 23, 2006 | 02:23 AM
smelser98's Avatar
smelser98
Default backfiring
my 98 5.2 was idling rough then at low rpms it would hessitate backfire through the throtlebody i got 2 codes both 02 sensors max volts I replaced them fixed it for 50 miles then same codes so I replaced the tps,both 02's,iac,map 50 miles later same problem any ideas
Old Jan 23, 2006 | 05:32 PM
Junior5290's Avatar
Junior5290
Default RE: backfiring
Sounds like you have an ignition problem, if it is backfiring, the o2's will read rich due to cylinders missing. You could have anything from a coil, bad ground to just needing a tune up
Old Jan 23, 2006 | 11:53 PM
smelser98's Avatar
smelser98
thanks it could be the coil or pickup module or crank sensor the truck has a accell hp coil the problem is intermitant and at low idle
