rpms jump up and then plumit.
Subscribe
Feb 28, 2006 | 06:15 PM
RE: rpms jump up and then plumit.
Have had it replaced on my Dak b4. The sending unit, pump and filter are all one unit inside the fuel tank.
Reply 0
Feb 28, 2006 | 07:33 PM
Just got my truck and it almost does the same thing. Sometimes after braking or coming to a complete stop the truck will drop its rpms below 500 and then kick itself back up before it dies. Never stalled, and this "bounce" only happens every once in a while. Also it only drops one or two times before returning to a normal idle. Do you think I am going to have a problem as severe as his? Could I just be in the preliminary stages of his more serious issue? Whatever the case may be, I'm very interested to see what comes of this.
Reply 0
Feb 28, 2006 | 08:58 PM
Seeing as there is no check engine light, I'd guess Fuel Pump/Fuel Filter... which is all one unit, and is located in the top of the fuel tank ... Auto Zone price is somewhere close to $300 for the unit, if I remember right.
How many miles on your truck? [sm=smiley25.gif]
Reply 0
Feb 28, 2006 | 09:04 PM
There was about 69,000 when I had mine replaced. I have about 74000 on it now.
Reply 0
Feb 28, 2006 | 10:51 PM
ive got 71k on mine. i will most likely replace fuel pump assy cause i know now its not map sensor, iacv, or tps. could still be check valve but i doubt it, so thanks alot for the help gentlemen.
Reply 0
Feb 28, 2006 | 11:12 PM
Dont know if you have 15 gal or 22 gal tank, but here is some fuel pumps under $300.00. Fuel Pumps
here are some on eBay for a lot less than $300. Dakota Fuel Pumps eBay
Reply 0
Mar 1, 2006 | 12:02 AM
wow thanks a lot but how do i know which to get? there are two different ones for my year and engine- chassis? i may be able to tell if i can get a closer look at the top of my pump? i have 22gal and i think its on top of fuel tank.
Reply 0
Subscribe
