interior light problems! HELP!!!!
Old Mar 3, 2006 | 02:35 AM
bigd25x's Avatar
bigd25x
Default interior light problems! HELP!!!!
Just bought my truck 2 days ago (97 Dakota SLT), went to install a aftermarket radio and the 12v constant power wire hit a ground wire and i heard a pop and all my Interior lights went out and my radio doesnt work. checked ALL the fuses under dash and underhood. someone said it was probley a relay but i have no idea what one or where. PLEASE HELP!!
Old Mar 3, 2006 | 03:23 AM
bigd25x's Avatar
bigd25x
Default RE: interior light problems! HELP!!!!
anyone??? please!!!!
Old Mar 3, 2006 | 10:11 AM
RP Racing940's Avatar
RP Racing940
Theres a fuse panel in thw side of thw dash. There should be a fuse in a wierd looking holder that shuts the lights off if you have to work with the doors open for a while. 10 to 1 its just a fuse popped and you missed it checking them (some times blade fuses can be a bear looking for a burnt one).
Old Mar 3, 2006 | 05:52 PM
bigd25x's Avatar
bigd25x
everyones just saying its a blown fuse. ive checked all the fuses and the ones under the hood, what one controls the radios constant 12v wire and the interiror lights? there might be a big fuse (like a metal block?) or a fuseable link i heard.
Old Mar 3, 2006 | 07:55 PM
bigd25x's Avatar
bigd25x
ok well i had my car stero place check it out, they checked every fuse. they said the only thing left is a "Fuseable Link", my mirrors\interior lights\12v constant radio wire dont work. Ideas please please please?
Old Mar 4, 2006 | 12:36 AM
batman13's Avatar
batman13
Check the wires, I don't belive dakotas to have fusable links, I've only seen them in imports, Chances might be that the fuse never popped when it should have and you could have fried a wire, start at the underhood fusebox and work your way towards the cab, The wires are probably in a loom so be very careful to look for and signs of damage, any slight amount of melted plastic would be a big clue, if you don't see any, open the loom (its just a cover, it should be slit)
and check all the wires, this is a very tedious process but make sure you don't miss a thing. If you don't see any problems in the engine compartment, It could be behind the dash, {just hope that it isn't back there.}
good luck, post any updates
BTW, I don't have a relay for the radio, or any fuseable links i just checked
________
Manual Inhale Vaporizer
Old Mar 4, 2006 | 12:38 AM
batman13's Avatar
batman13
Also, I reccomend disconnecting the battery.
________
SIDE EFFECTS FROM ZOLOFT
Old Mar 5, 2006 | 05:22 PM
bigd25x's Avatar
bigd25x
i found out what it was, there was a fuse in the fuse pannel with a black cover over it, you have to take it off with a screw driver and it was blown to hell. called like I something, my nabor does electrical for dodge he told me ;-)
Old Mar 5, 2006 | 11:44 PM
batman13's Avatar
batman13
thats good, I found the one you're talking about, I see why it was difficult
________
Zoloft settlement information
Old Mar 6, 2006 | 11:30 PM
titan2087's Avatar
titan2087
dont you love them hidden babys!!!
