Windshield Washers freezing
Old Mar 5, 2006 | 01:44 PM
CDakota's Avatar
CDakota
Default Windshield Washers freezing
Has anybody else had a problem with the windsheild washer lines freezing up. I asked the guy at the dealer and he said that it happens, but I thought maybe he was just trying to get out of work. Its starting to become a real problem.
Old Mar 5, 2006 | 03:23 PM
horatio102's Avatar
horatio102
Default RE: Windshield Washers freezing
Buy the cold weather washer fluid (it's got alcohol in it) and don't dilute it. Normal stuff mixed with water freezes a lot closer to 32* whereas the winter stuff has a much lower freezing point. And IMHO it works better that way.
But yeah, if it's cold out your washer lines can freeze.
Old Mar 6, 2006 | 05:59 AM
deranged's Avatar
deranged
Prestone makes cold weather washer fluid that works quite well.
Old Mar 6, 2006 | 10:23 AM
gutted's Avatar
gutted
ORIGINAL: horatio102
Yeah, if you are dilluting, stop doing that. In the summer I'll run almost half and half, but in the winter I only use washer fluid. I usually use the deicing stuff in the winter, it costs about the same anyway.
Old Mar 6, 2006 | 05:38 PM
trucker 41's Avatar
trucker 41
I had the same problem, and I put some -45C and the problem disapeared.
