ABS???
Old Mar 9, 2006 | 10:27 AM
Robertwav1's Avatar
Robertwav1
Default ABS???
I have a 98 dakota. The ABS light comes on normal when starting or turning the ignition on and goes off like it should. This winter I have tried the brakes on ice and the ABS don't seem likes it working....I can lock the wheels. I have no ABS light warning of any kind. Am I missing something here? I don't know if it's working or not??? Appreciate any input that you may have...Thanks!
Old Mar 9, 2006 | 12:59 PM
db252's Avatar
db252
Default RE: ABS???
Well, it kinda depends. Our Dakotas come standard with REAR ABS but FRONT ABS is optional. Look behind your front hubs and see if there is a wiring harness coming from them. If there isn't, you don't have front ABS and therefore can lock up the front end from heavy braking.
Old Mar 9, 2006 | 03:33 PM
Robertwav1's Avatar
Robertwav1
Default RE: ABS???
Thanks and I will check that out this weekend.
Old Mar 10, 2006 | 02:50 PM
cbsaint's Avatar
cbsaint
Default RE: ABS???
Wouldn't it make more sense to put the standard ABS on the front and not the back, from a safety standpoint? I'm guessing they did it the way they did for cost, instead.
