Truck Specs
Can anyone tell me if there is a quick/easy way to find out the full spec sheet on my truck, besides the spec sheet that would have been on the window? I bought the truck used, so no spec sheet...
heres engine specs General Engine Specifications Engine Type 90 ° SOHC V-8 16-Valve
Displacement 4.7L / 4701 cc (287 cu. in.)
Bore & Stroke 93.0 x 86.5 mm (3.66 x 3.40 in.)
Compression Ratio 9.0 : 1
Horsepower 235 bhp @ 4800 RPM
Torque 295 lb-ft @ 3200 RPM
Lead Cylinder #1 Left Bank
Firing Order 1-8-4-3-6-5-7-2
4WD
I was hoping for a list of installed options and features and standard equipment. ie. Anti-Lock Brakes (All 4 wheels or just 2), the axle type and size (Dana 44, etc), pretty much some detailed information.
I'm sure that I am asking a lot and there's probably no chance without having someone look at it, but I figured I'd give it a shot.
The best way to get acurate specs on any vehicle is to try www.cars.com and click the research tab on the top of the screen. It shows all the stock specs including options avaliable for that specific vehicle and year.
