front hub nut
Old Apr 24, 2006 | 08:28 PM
97dak39's Avatar
97dak39
Default front hub nut
im taking the brakes off of my 1997 dakota 3.9 4x4. the front rotors need to be replaced. i can get everything off except the hub nut. if the 4x4 isnt engaged the rotor just spins freely. i put it in 4x4 and tried turning it but when it didnt brake loose i didnt wanna try to turn it to hard and brake the transfer case or anything. any ideas? do you have to have a special wrench or something?
Old Apr 24, 2006 | 08:49 PM
marks99dak's Avatar
marks99dak
Default RE: front hub nut
do not remove the hub nut otherwise you have to replace it the rotor is separate it may take a little force to get off i replaced my rotors and the passenger side was a bitch to get off unless you want to get a new nut from dealer ($10.00 each) just my opinon
Old Apr 24, 2006 | 09:41 PM
97dak39's Avatar
97dak39
ok i uh unfortunatly i pulled the nut off the driver side. why cant you pull the nut off? i cant git the rotors off and iv pryed against them time and time again and they havnt even budged
Old Apr 24, 2006 | 10:13 PM
marks99dak's Avatar
marks99dak
because the inside is nylon coated and the nut says do not reuse
Old Apr 25, 2006 | 08:31 PM
marks99dak's Avatar
marks99dak
beings you have it off a slight tap on the ground should loosen the rotor off the hub
Old Apr 25, 2006 | 11:37 PM
97dak39's Avatar
97dak39
ok well the driver side was so hard to get the rotor off. i had to take a wood splitting wedge and drive it in the to break it loose. i havnt done the pass. side yet
Old Apr 26, 2006 | 08:46 PM
marks99dak's Avatar
marks99dak
good luck, too bad its too expensive to have the brakes done by someone else- then it could have their headache and not yours
Old Apr 26, 2006 | 09:46 PM
shnormo's Avatar
shnormo
God damnit haven't you ever heard of a gear puller? a 3 arm puller a 13" should be fine. There are also special tools, but they cost a lot more than a gear puller.
Old Apr 27, 2006 | 12:01 AM
horatio102's Avatar
horatio102
Or just smack it with a dead blow.
Mine weren't stuck though.
Old Apr 28, 2006 | 01:56 PM
97dak39's Avatar
97dak39
well i was running out of time to get it to the inspection station i had to get it there that day and didnt have time to go get a puller. so i had to do the pass. side the same way. i tried just tapping that side off but yet again it didnt come off and i had to use a wedge. but its all done now. i hads always wondered why the truck had trouble slowing down and it failed inspection. oh and about taking it to someone...i can do pretty much anything. and i dont feel like payin 80 dollars an hour for as little trouble as it was. in 10 minutes i took the pass side tire off, had the calipers off and had the rotor off.
