Turn signal
Old Apr 27, 2006 | 08:42 PM
flyboy08's Avatar
flyboy08
Default Turn signal
Ok...my drivers side signal is out. Of course, it the one on the outside of the two. The inside one can easily be turned and removed, but the other one, there is not enough clearance to pull out the bulb!!!!
Do I need to take the lens off from the OUTSIDE to change this bugger? I see a small hex, but that's about all. If so, what size is this little bastard! Allen's dont fit!
As always, TIA.
Old Apr 28, 2006 | 07:16 AM
horatio102's Avatar
horatio102
Default RE: Turn signal
yeah, remove lense. Try a torx wrench, I haven't looked into it but if allens aren't working, there might be a reason
