running hot
Old Jul 3, 2006 | 02:57 PM
00 SLT Owner's Avatar
00 SLT Owner
Default running hot
I need some help guys. I have a 00 dak slt. It has been running hot for about a month now. I changed the thermostat, which was stuck, and have flushed the radiator but I am still running hot. The new t-stat I put in was a 180 deg. I have no bubbles in my resivour so I don't think it's a bad or cracked head. I never let it get so hot that it over heats. I will stop and shut down the engine if it reaches 240 deg.
Old Jul 3, 2006 | 03:09 PM
kikoy's Avatar
kikoy
Default RE: running hot
you still mostlikely to have some air pocket in it...but as you said its been a month......id try to look @ your fan clutch and or your electric fan.....
Old Jul 3, 2006 | 03:48 PM
butchowens's Avatar
butchowens
Replace your fan clutch. It probably isn't engaging properly. If you have the heavy duty service group truck also verify your electric fan is working. This can be done by turning on the ac
Old Jul 4, 2006 | 09:01 AM
Dodge_dakota's Avatar
Dodge_dakota
You also might want to check your water pump
Old Jul 5, 2006 | 01:55 AM
Fabulous's Avatar
Fabulous
you can always give the hoses a pressure test
